[Android] Graphic Problem with the Rotation of the Screen
This is a discussion on [Android] Graphic Problem with the Rotation of the Screen within the Android Graphics forums, part of the Android Discussions category; Hi all, I've got a HTC Wildfire with Android and also the last version from the Waze client installed. I'm going through the next problem: ...
Thread: [Android] Graphic Problem with the Rotation of the Screen
    Android Lurker koyalko's Avatar
    Feb 2012
    Hi all,
    I'm going through the next problem: after i rotate my smartphone, to be able to get yourself a bigger look at the region, it takes place the vehicle in Waze isn't any more on the highway, but about 0.5 centimetres around the left.
    I believe this can be a little graphic bug, that may be fastly resolved.
    Furthermore it may be very interesting to use recption menus the chance to bar the screen, therefore it can't turn even when the smartphone is incorporated in the horizontal position. I frequently use Waze with my motorcycle and that i usually place the smartphone within the tank-bag. Sometimes the smartphone turns within the bag, because you will find lots of holes in roads and that i don't want the screen rotates itself.
    take care ..
    Android Lurker torieomufnill's Avatar
    Feb 2012
    Normally these problems occur when you tilt the phone. The may the problem with the image resolution
    Android Lurker larsonb's Avatar
    Mar 2012
    image resolution mean can i have clarity on this.
  1. Graphic Designer With Android Fetish here!
    By dbenton25 in forum Introductions & Site Assistance
    Last Post: 02-09-2012, 04:09 AM
  2. Great comparison graphic to all the "Droid" phone features
    By feverhost in forum Motorola Droid 2 Global
    Last Post: 01-21-2011, 07:35 PM
  3. Screen Problem, anyone else have a "rattling" screen?
    Last Post: 11-30-2010, 04:41 PM
android bug when rotation
android rotation
android screen rotation graphic glitches
epic 4g orientation problems
epic 4g screen graphic glitches
epic 4g screen orientation problem
epic 4g screen rotation problems
htc wildfire rotation screen problem
rotatation problm graphics
rotation problems of graphics
smartphone android screen rotation problem
waze graphic error
waze screen rotation
