Android Lurker
Not Reacting to Mem Stick Pro Duo
my psp 1001 fat is not having any reaction to a memory stick pro
duo, the magicgate light does nothing and the psp says there is no
card in the reader. works in my computer, formatted it to
everything my computer can do and theres no change for the psp. i
dont have another psp to test it in, but it used to only work if i
held it in as far down as it would go, without really forcing it.
now it doesnt click back when its pressed on and gets a bit stuck,
i plan on opening it and seeing if i warped something, but if
anyone can give me tips on what to look for id greatly appreciate
it
09-27-2012 09:25 PM
# ADS
