Android 4.3 Will Likely Speed Up I/O Performance of Previous Generation Nexus 7
This is a discussion on Android 4.3 Will Likely Speed Up I/O Performance of Previous Generation Nexus 7 within the Android News forums, part of the Android.net category; Has the performance of your OG 2012 Nexus 7 seemed to be getting slower and slower over time? If you have experienced this, you are ...
Like Tree1Likes
  • 1 Post By dgstorm
Thread: Android 4.3 Will Likely Speed Up I/O Performance of Previous Generation Nexus 7
    Editor in Chief dgstorm's Avatar
    711 times
    Has the performance of your OG 2012 Nexus 7 seemed to be getting slower and slower over time? If you have experienced this, you are not alone. It was apparently an I/O issue which will likely be vastly improved with the new Android 4.3 update. According to the latest info, some lines of code have been found within Android 4.3 which will enable something in the background called TRIM. It's basically a new functionality which cleans up the internal memory on your device and dumps out all the old and unused files.
    Sound off if you are one of the lucky folks who has received their Android 4.3 on your older Nexus 7 and let us know if it has helped your performance.
    Source: Phandroid
    UltraDroid likes this.
    520 times
    I received the 4.3 update on Wednesday and really haven't noticed a lot of change. It made a few changes in how things were displayed on the tab, but other than that I haven't personally seen much difference - bring on Android 5.0!
  1. Replies: 0
    Last Post: 07-26-2013, 03:54 PM
  2. Replies: 0
    Last Post: 07-24-2013, 12:33 PM
  3. Pics & Video Leak of the Next Generation Nexus 7
    By dgstorm in forum Android News
    Last Post: 07-18-2013, 10:55 AM
  4. Wifi Performance. Speed test fun!
    By ScottyPimpin in forum Nexus One
    Last Post: 03-25-2010, 04:53 PM
  5. Replies: 10
    Last Post: 03-13-2010, 04:12 PM
