The Edge version of T-Mobile's Samsung Galaxy Note 4 is the next device to get the Android 5.x Lollipop treatment. Last week, the Galaxy Note 4 started getting the update, so it was obvious it wouldn't take too long for the Galaxy Note Edge to get it, (since they are very similar devices and built on the same core hardware).
The version is Android 5.0.1 and weighs in at a portly 1.84GB. Of course, this has most of the usual Lollipop goodies, although Touchwiz does obscure some of the Material Design UI. Still, it also adds: Smart Lock, priority notifications, an improved lockscreen, as well as several other tweaks.
As usual, if you don't want to wait for the OTA update wave to hit your device, the manual option is Samsung Kies. Sound off if you are a proud owner of this device and let us know when you get the update!
Don't forget to check out our dedicated Samsung Galaxy Edge section for further discussion: Samsung Galaxy Note Edge | Android Forum at DroidForums.net
Source: T-Mobile
