Passive Wi-Fi Uses 10,000 Times Less Power Than Standard; Likely to Replace Bluetooth
This is a discussion on Passive Wi-Fi Uses 10,000 Times Less Power Than Standard; Likely to Replace Bluetooth within the Android News forums, part of the Android.net category; Engineers in the United States have made the final breakthrough for technology called Passive Wi-Fi. It's set to drive the revolution of the IoT (Internet ...
Thread: Passive Wi-Fi Uses 10,000 Times Less Power Than Standard; Likely to Replace Bluetooth
    Editor in Chief dgstorm's Avatar
    711 times
    Engineers in the United States have made the final breakthrough for technology called Passive Wi-Fi. It's set to drive the revolution of the IoT (Internet of Things) and replace Bluetooth eventually. Passive Wi-Fi can generate an 11Mbps Wi-Fi connection, and although that doesn't seem very impressive, it does it with 10,000 times less power than standard Wi-Fi connections.
    Additionally, the latest successful tests for Passive Wi-Fi had a range of 100 feet (30 meters) and consumed 1,000 times less energy, but with up to 11 times faster speeds than existing low energy standards, like Bluetooth and Zigbee.
    Here's a quote with a few more details,
    "To achieve such low-power Wi-Fi transmissions, the team essentially decoupled the digital and analog operations involved in radio transmissions.
    The Passive Wi-Fi architecture assigns the analog, power-intensive functions - like producing a signal at a specific frequency - to a single device in the network that is plugged into the wall.
    An array of sensors produces Wi-Fi packets of information using very little power by simply reflecting and absorbing that signal using a digital switch."
    Joshua Smith, associate professor of computer science and engineering had this to say about the breakthrough, "Now that we can achieve Wi-Fi for tens of microwatts of power and can do much better than both Bluetooth and ZigBee, you could now imagine using Wi-Fi for everything."
    It's amazing the magical things the wizards of engineering can create! Check out the video in the thread below for a demo of the new Passive Wi-Fi tech.
    Source: gadgets.ndtv
    711 times
    Here's that video of Passive Wi-Fi in action:
  1. Boot into recovery from power off without power button
    By funless in forum Nexus One Tech Issues / Bug Reports
    Last Post: 12-23-2010, 01:23 PM
  2. Music thruogh standard bluetooth headset NOT stereo
    By Christiebunny in forum LG Ally
    Last Post: 10-24-2010, 04:27 PM
  3. Some times Title is BOLD and some times it isn't
    By herbmmm in forum Nexus One
    Last Post: 04-01-2010, 06:26 PM
  4. Email and standard text
    By axel in forum Nexus One
    Last Post: 03-05-2010, 05:50 AM
  5. Power Button - Long press to power up
    By xPatriicK in forum Nexus One Tech Issues / Bug Reports
    Last Post: 01-17-2010, 11:04 AM
