[DROID X GUIDE] Modifications: Should you do it...read this first!!!
This is a discussion on [DROID X GUIDE] Modifications: Should you do it...read this first!!! within the Android Rooting forums, part of the Android Development category; I'm putting this guide together to help new users decide if certain modifications are for them or not. There are many mods being thrown on ...
Thread: [DROID X GUIDE] Modifications: Should you do it...read this first!!!
    El Paso, TX
    59 times
    _B0BB0_
    I'm putting this guide together to help new users decide if certain modifications are for them or not. There are many mods being thrown on phones that most users don't even know what they do. Research is the best resource. Don't do something to your phone without knowing what it does and how to uninstall it.
    ROOT
    Root is having administrative access to your phone. This allows you full control over all aspects of your phone to include system files.
    Benefits
    1. You can remove unwanted system apps (bloatware) on your phone.
    2. You can improve speed by overclocking the CPU
    3. You can create a wireless hotspot
    4. You can install custom themes for
    5. You can install custom ROMs
    Risks
    1. You will void your one year replacement warranty if VZW finds out you're rooted
    2. You open your phone up to powerful apps/modifications that can cause serious damage if you're not careful with them.
    Removing Bloatware
    This involves either deleting, renaming, or freezing unwanted system apps.
    Benefits
    1. Improved battery savings by removing constantly running system apps.
    2. Cleaner looking app drawer
    Risks
    1. Removing a vital system app can cause serious issues with your user interface.
    2. Deleting, renaming, or freezing system apps may cause issues with receiving OTA updates from VZW.
    3. Some system apps may not work if a complimentary app is removed.
    Overclocking
    This involves using a third party app to increase the clock speed over the stock 1.0ghz processor.
    Benefits
    1. Improved performance.
    2. Faster transitions.
    Risks
    1. Shortened processor life.
    2. Overheating which also can lead to a lower life span for the processor.
    3. When "Set at boot" option is selected, bootloops can occur if overclock speed is not set at a stable speed.
    Tethering
    This involves downloading a tethering app that will turn your phone into a ad hoc wireless hotspot.
    Benefits
    1. Ability to connect other wireless devices to the internet via the phones 3G signal.
    2. No need for an additional internet provider.
    Risks
    1. Heavy battery drain, which can lower the life span of the battery.
    2. Tethering large amounts of data will catch the eye of VZW.
    TBH 3G Hotspot Patch
    This is the official VZW hotspot being hacked into to provide 3G hotspot benefits without being charged for its use.
    Benefits
    1. Better/truer connection than ad hoc tethering.
    2. No need to pay additional fees for use of the official VZW service.
    Risks
    1. This is a direct violation of your terms of service with VZW.
    2. VZW WILL terminate your contract if this is found.
    3. Using large amounts of data will also put you on VZWs radar.
    Removing the data governer/throttling
    VZW lowers data speeds to users who use more than 5gb and during peak bandwidth usage times and this hack removes that data limit. This does not necessarily increase speeds for average users.
    Benefits
    1. More constant data speeds for heavy users.
    2. No drop in down/upload speeds.
    Risks
    1. You are modifying the services.jar, if you don't know what this is, perhaps you shouldn't be modifying it.
    2. Can no longer turn off 3G in settings.
    Themes
    Themes modify the framework of your phone.
    Benefits
    1. The ability to customize your phone.
    Risks
    1. Bootlooping if not installed correctly.
    ROMs
    ROMs change the entire system of the phone.
    Benefits
    1. Increased performance.
    2. Easier to use interface.
    3. Ability to customize the system.
    Risks
    2. Bricking your phone and needing to SBF.
    3. Permanent brick.
    These are a few of the more common modifications taken on by many users of the X. If I left something out or if you would like something described more in detail, let me know. This is more of a guide for new users rather than more experienced users. So help if you can. Thanks, Rob
    El Paso, TX
    59 times
    _B0BB0_
    Reserved for ramblings...
    Android Jr Member Ubermicro13's Avatar
    Massachusetts
    I have the throttling removed and I can still disable 3G. If I try to do it from the settings menu sometimes it bugs out but SwitchPro widget works fine to do it.
    Sent from my DROIDX using Android.net App
    El Paso, TX
    59 times
    _B0BB0_
    Correct, you can use a third party app to toggle it off/on but normally you can't do it from settings/mobile networks.
  1. Guide of Converting DVD to Zune
    Last Post: 12-23-2010, 12:54 AM
  2. Sprint Battery Boost PLEASE READ IF YOU'VE BOUGHT
    Last Post: 09-06-2010, 02:46 PM
  3. Samsung Epic 4G user's guide
    Last Post: 08-31-2010, 11:14 AM
droid x 3g speed hack
droid x improve performance
droid x modifications
droid x service 3g hack
droidx service hack
how to improve droid x performance
how to improve my droid x
how to improve the droid x
how to increase my droid x speed
improve droid x
increase droid x speed
increase internet speed droid x
modifications for droid x
remove data throttle
