VERY Basic Question (Opening an Android Project)
This is a discussion on VERY Basic Question (Opening an Android Project) within the Beginning Developers forums, part of the Android Development category; I have a very very BASIC question and would appreciate if someone help me How do you OPEN an application using Eclipse? I mean I ...
Thread: VERY Basic Question (Opening an Android Project)
    Android Lurker KansaiRobot's Avatar
    Japan
    I mean I have tried my first two android projects FROM SCRATCH and run them successfully.
    But now I want to open someone else's project (some example codes). But I can't and I don't know how.
    1) Which one of the numerous files is the "project file"?? (is there one?)
    Now, I asked and got two responses, both of them don't work
    one person said:
    File->New->Project and create project from existing source...
    I tried that but it says "it already exist another project on the workspace, try importing"
    so i tried that other option
    File >Import >General> Existing Projects
    When I did that it "opened" the project but very weirdly. First it is FULL of errors..(and obviusly cant run it) and even in the source section there is not only the source files but also com and com.androidbook etc other files that never should appear...
    I dont remember the error message but will post it later
    so please
    How do you guys open an existing android project in Eclipse? (a step by step tutorial would be great)
    Thanks for all the help..
    Kansai
    App Developer alostpacket's Avatar
    NY
    31 times
    alostpacket
    Make sure to remove any conflicting files from your workspace, and use the first method (if it's an android project)
    hth
  1. How to switch basic Android storage
    By Raeion in forum Introductions & Site Assistance
    Last Post: 08-11-2011, 02:39 PM
  2. Opening mms on Galaxy Ace
    By dogla in forum Android Forum
    Last Post: 04-27-2011, 08:56 AM
  3. Can i get the Basic's
    By stan877 in forum Samsung Transform
    Last Post: 03-28-2011, 12:23 AM
  4. Replies: 7
    Last Post: 02-10-2011, 01:54 PM
  5. Problems in opening picture text messages
    Last Post: 09-19-2010, 12:45 AM
android basic questions from coding
can samsung galaxy ace open mms
galaxy ace mms
galaxy ace mms setting
galaxy ace projects
how to open an mms of a samsung galaxy
how to open an mms on samsung android
how to open mms in samsung galaxy ace
how to open mms on samsung galaxy
how to open someone elses android project
how to recieve picture messages on galaxy ace
open someone else's android project
opening an android project
samsung galaxy ace mms setting
start android application from someone elses source eclipse
