//Show result
protected void showResult(Editable first, Editable second) {
float num1 = Float.parseFloat(first.toString());
float num2 = Float.parseFloat(second.toString());
float result = num1 * num2;
float result2 = result / 12;
float result3 = result / 50;
float result4 = result / 29;
float result5 = result / 50;
Result.setText(String.valueOf(result)+ " in2" + String.valueOf(result2)+ " inches of x2." + String.valueOf(result3)+ " inches of x3." + String.valueOf(result4)+ " inches of x4." + String.valueOf(result5)+ " inches of x5.");
Does not work when the Calculate button is clicked. But this works if I stop at:
Result.setText(String.valueOf(result)+ " in2");
Textview is defined like this:
Result=(TextView) findViewById(R.id.TextViewIt);
