Problem to Dynamic Connect to postgreSQL
This is a discussion on Problem to Dynamic Connect to postgreSQL within the Beginning Developers forums, part of the Android Development category; Hi everyone. I'm newbie in android. I've dynamic connected completely to postgreSQL in code below: Code: EditText Address, Port, Database, User, Pass; Connection connection = ...
Thread: Problem to Dynamic Connect to postgreSQL
    Android Lurker whiteboy's Avatar
    May 2012
    Code:
        Connection connection = null;
        public boolean get_connection(){
            String address, port, database, user, pass;
            address = Address.getText().toString();
            port = Port.getText().toString();
            Database = Database.getText().toString();
            user = User.getText().toString();
            pass = Pass.getText().toString();
            try {
                Class.forName("org.postgresql.Driver");
            } catch (ClassNotFoundException e) {
                e.printStackTrace();
                return false;
               String url = "jdbc:postgresql://" + address + ":" + port + "/" + database;
               try {
                   connection = DriverManager.getConnection(url, user, pass);
                } catch (java.sql.SQLException e) {
                       return false;
                return true;
    I don't know how to hold that connection information to use for many others activities-java class(EX: for each time one Activity want to connect to load data can use that connection information). Thank in advance.
    520 times
    Hello whiteboy, and welcome to the forum!
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Can't help you with the task at hand, but can welcome you to the site!
    Android Lurker ebookren's Avatar
    Aug 2012
    I notice you use the same String names, one uppercase one lower. Your Database= Database Should be database=Database.getText().toString()
    Chris
    Sent from my Nexus 7 using Android.net
  1. how to connect?????
    By rachitdon in forum Samsung Galaxy S2
    Last Post: 09-27-2011, 11:35 PM
  2. Wi-Fi won't connect
    By JaneInVegas in forum Motorola i1 Tech Support
    Last Post: 07-23-2011, 02:07 AM
  3. connect with pc
    By zsuzsanna19 in forum LG Ally Help
    Last Post: 07-05-2011, 05:52 PM
  4. Dynamic (configurable) endpoint address
    By ampo in forum LG Ally Help
    Last Post: 02-27-2011, 03:57 AM
android class.forname(org.postgresql.driver)
android connect to postgresql
android postgres connection
android postgresql
android psql
connect android postgresql
connect android to postgresql
connect postgres on android
connect to postgres database android
connectio pgsql android
how to connect android to postgresql
postgres on android
postgresql on android problems
postgresql to android connection
use postgres in android
