Have you ever feel that you need to charge your ipad or iphone frequently? Here we have a solution now, we recommend you the
5000mAh External Battery Pack Power Bank for iPhone/iPad/PSP/Camera/MP3/MP4
8 different connector for every kind of mobile phone or tablet.
Specifications:
  • Just snap on the battery charger gently then it begins to charge instantly
  • You can charge your battery with this battery charger while driving
  • With the simple and practical design and high quality material, this battery charger is easy and durable to use and operate
  • As the green environment protection, this portable charger does not produce the wastes while charging
  • The portable charger is very durable and convenient to use
  • This multifunction portable charger can charge many electronic equipments including your mobile phone
  • This is a NON-OEM product
  • Input: DC 5V 1A
  • Output: DC 5.0V 1A
  • Capacity: 5000mAh
Package Included:
  • 1 x Double USB 5000mAh USB Power Bank
  • 8 x Connectors
  • 1 x Retractable USB Cable
Here are some coupons you may interested in:
Extra 6% off storewide on any orders. Coupon Code: FONAREVKA
Extra $10 off storewide on orders above $50. Coupon Code: SAVE10BR
Extra $18 off storewide on orders above $80. Coupon Code: SAVE18OFFBR
Extra $20 off storewide on orders above $100.Coupon Code:DDCHRISTMAS
