Problems , Problems , Problems
This is a discussion on Problems , Problems , Problems within the HTC EVO 4G Tech Support forums, part of the HTC EVO 4G category; For the last few days my Evo has been acting very strange . It started with the screen freezing and having to do a battery ...
Thread: Problems , Problems , Problems
    Member Mr Triumph's Avatar
    It started with the screen freezing and having to do a battery pull ,and even turned it off and let it reboot many times just to get texts and emails ,
    then it started loosing 3G connection or to no service , and just now its sitting on charge and it wakes up so I turn it off and after a few mins it dose it again :confused:
    Have you tried doing a factory reset?
    Thats what Im trying right now .
    Member Varo's Avatar
    Are you rooted and using an Overclocking or Underclocking rom or Kernel? Most phones freak out when you get them too low.
    Junior Member bikerbyrd's Avatar
    Ok I had the same problem with my Evo and I just got it replaced. There seems to be a bad batch out there. Sprint worked on mine three times and couldn't get it to work right. It was freezing up and signal was weird on 3g and 4g won't work. It would also shut itself down and restart without touching it. It was like a bad horror movie. I lost all my media files on the phone and it would ghost my contacts. One minute they are there and then there not. Sprint Tech support wasn't sure what to do because its such a new phone and they haven't had enough experience with it yet. But I'm glad I'm not the only one cause it was spooky.
    well after a lil of cussing at it , and a factory reset it is working just fine .
    ******OH and just dont assume that you backed up you phone KNOW that you did , I assumed and lost EVERYTHING but oh well .*******
    Ok i got EVO replaced after all the issues I was having and WOW the first one I got definitely didn't work right this thing kicks ass. So if you're having any issues with yours make sure you get it looked at. My last one couldn't be helped had it looked at a few times even had it reset and it would work for a little while then the gremlins would come back. Good luck
  1. Android Chipping Away Market-share from iPhone Fast!
    Last Post: 01-03-2011, 05:24 PM
  2. Updated Info for Sony Playstation App
    Last Post: 12-30-2010, 02:27 PM
  3. Is the task killer necessary?
    Last Post: 12-10-2010, 03:58 PM
  4. Help--I have two problems!
    Last Post: 09-03-2010, 08:59 PM
  5. Samung Epic 4g HD Video Test by Server09
    Last Post: 09-01-2010, 08:07 AM
evo 4g acting crazy
evo acting crazy
evo shift 4g acting wierd
evo shift acting crazy
htc acting funny with horror face
htc evo 4g acting weird
htc evo 4g acts crazy
htc evo acting crazy
htc evo acting strange
htc evo acting weird
htc evo shift acting weird
my evo is acting crazy
what causes my htc evo phone to act crazy
why does my htc evo act crazy
why is my evo acting weird
