Can it be done?If so, the method escapes me....
I like the option for both. It helps when I'm in a noisy environment and my hearing's not so good.
Cheers!
Micael
This is a discussion on Is there a way to have both Sound ON *and* Vibrate Mode ON? within the HTC EVO 4G forums, part of the HTC Android Phones category; Can it be done? If so, the method escapes me.... I like the option for both. It helps when I'm in a noisy environment and ...
Cheers!
Micael
I have the same problem after my device updated to 2.2. I had it before and I enjoyed having the option of both but I haven't found a way to get that back.
Sent from my Ally using Android.net App
Thanks for the response, Jon. Apparently this isn't an issue with anyone else.
Y'know..I think I had a widget that allowed this combo, but it was a while ago and I dropped a bunch of apps to save memory. I'll see if I can dig it up.![]()
Beauty is in the eyes of the beerholder
IIRC, it was called Audio Manager Widget, and you simply check the vibrate box above the ringer volume adjuster in settings. HTH!![]()
Thanks alphawave7. I'm on it!
I used an app called cVolume. It let me control everything and even set up custom rules.
What's a Bieber?
