Having Problem with the Lockscreen Ring Getting Stuck Halfway on the Screen?
This is a discussion on Having Problem with the Lockscreen Ring Getting Stuck Halfway on the Screen? within the HTC Sensation 4G forums, part of the HTC Android Phones category; This already happened twice and there seems to be no way out except to reboot, and having a protective cover makes that inconvenient. Sometimes the ...
Results 1 to 10 of 14
Thread: Having Problem with the Lockscreen Ring Getting Stuck Halfway on the Screen?
    Android Lurker hubeyh's Avatar
    Jun 2011
    Sometimes the lockscreen ring will get stuck halfway on the screen. For some reason everything moves up and the top half of the screen disappears.
    IT seems there is something wrong with the modulo arithmetic. It opens up after many attempts and then it has to be rebooted.
    The first time around, I thought it might have been some new apps I installed, so I uninstalled them. It happened again, right now.
    Is anyone aware of this problem?
    Somewhere on Kamino
    83 times
    I haven't heard of this yet. Someone should be by that may be able to answer.
    Android Lurker Kameleon's Avatar
    Jun 2011
    Hi! I've been having the same problem but I don't have to restart, all that is required is dragging the ring where it should be not where it appears to be. Very annoying when it happens though.
    Jun 2011
    Quote Originally Posted by Kameleon View Post
    Aha. I have to try this next time. After it works, does it go back to normal or do I still have to reboot? Does anyone know if this is possibly a HW glitch? e.g. should I exchange it?
    Android Lurker violetsunset's Avatar
    got the same problem, tried everything but only rebooting made it back to normal. This is the first time i got this after downloading a dictionary app
    62 times
    I've shunned Sense, and use LauncherPro and the app 'No Lock' since I don'e even want a locked screen, and have had no issues.
    Beauty is in the eyes of the beerholder
    Android Lurker cnulman's Avatar
    I have this same problem on my HTC EVO 3D. I did not install the dictionary program as another user indicated.
    Android Lurker odfaour's Avatar
    Sep 2011
    Same problem
    Sent from my HTC Sensation Z710e using Android.net
    Android Lurker vtech's Avatar
    Dec 2011
    I need help rooting my htc sensation
    Android Lurker hamede900's Avatar
    Jan 2012
    same problem
    hi
    same problem too , is rooting helps ? or flashing with custome rom ? >
  1. Corporate Exchange Stuck on "Loading" Screen
    By dstnd in forum Samsung Epic 4G Tech
    Last Post: 04-23-2014, 08:43 PM
  2. HTC Hero stuck on boot screen
    By Preston in forum HTC Hero
    Last Post: 10-27-2011, 07:46 PM
  3. Ring tone stuck
    By krystav in forum Rescue Squad Help
    Last Post: 08-30-2011, 11:57 PM
  4. Htc Hero Stuck on "HTC" screen. Help Please
    By kyleallen5000 in forum HTC Hero
    Last Post: 07-16-2011, 02:39 AM
  5. stuck at lg screen
    By jay_jay in forum LG Ally Hacking / Development
    Last Post: 04-15-2011, 10:35 PM
frozen screen htc sensation
how to repair htc sensaion lockscreen ring
htc lock ring problem
htc sensation frozen lock screen
htc sensation frozen on lock screen
htc sensation frozen screen
htc sensation lock screen frozen
htc sensation ring lock replacement
htc sensation screen frozen
htc sensation stuck on lock screen
htc sense screen frozen
remove lock ring on htc evo 3d
removing the ring from htc android
thunderbolt locked ring frozen
troubleshooting htc android rhyme frozen at pin lock location
