Newbie joining ... need help / advice
This is a discussion on Newbie joining ... need help / advice within the Introductions & Site Assistance forums, part of the Android Discussions category; Hello to all, I just bought a Motorola Xoom yesterday and i have been playing with it since and have encountered a few issues which ...
Thread: Newbie joining ... need help / advice
    Android Lurker Mr_Taz's Avatar
    Apr 2011
    Question Newbie joining ... need help / advice
    Hello to all,
    I just bought a Motorola Xoom yesterday and i have been playing with it since and have encountered a few issues which are probably due to my being new to this technology.
    Flash will not install ... I have read that there is a problem with it on a forum but that it was running just fine on another!
    Also I have several hundreds pictures I would like to transfer to my Xoom. Any ideas of any Apps that would do the trick? Can folders be created on the Xoom?
    Also playing with this new machine i have 2 or 3 icons of either an app or a widget on the same page ... Can we "delete" the extra ones?
    Thanks for your help
    Android Master tp76's Avatar
    Alternate Reality
    52 times
    androiddotnet
    Deleting an icon from a homepage does not uninstall the application - do so with confidence, as far as transferring pictures it should be as easy as connecting via USB to your computer and dragging the files over...
    Not sure why flash won't install for you, I had no issues doing so - you can also check out one of our sister forums
    Apr 2011
    Thanks TP76 ... file transfer working jut fine.
    El Paso, TX
    59 times
    _B0BB0_
    Welcome over here too!
    Apr 2011
    Ok all, issue solved .... I managed to "uninstall" the app and reinstall without a hitch ... suspect a bad download maybe ...
    again thanks for your help.
  1. Newbie here from NC
    By bsbabcock in forum Introductions & Site Assistance
    Last Post: 05-08-2011, 12:46 AM
  2. New newbie...
    By technopeasant in forum Introductions & Site Assistance
    Last Post: 04-25-2011, 07:56 PM
  3. newbie seeking advice
    By vierannie in forum Introductions & Site Assistance
    Last Post: 04-11-2011, 06:18 PM
  4. Joining from Droidforums.net
    By Bilgediver in forum Introductions & Site Assistance
    Last Post: 01-25-2011, 10:41 PM
  5. help a newbie
    Last Post: 10-30-2010, 05:01 PM
