HELP - messed up my android - no longer turn on
This is a discussion on HELP - messed up my android - no longer turn on within the Introductions & Site Assistance forums, part of the Android Discussions category; Hello My phone does not start, the only thing it does is when i turn on, is the screen that turns black (no apear motorola ...
Results 1 to 9 of 9
Thread: HELP - messed up my android - no longer turn on
    Android Lurker trivial's Avatar
    Jan 2012
    Hello
    My phone does not start, the only thing it does is when i turn on, is the screen that turns black (no apear motorola logo), but note that are connected, but dont appear nothing.
    Even when I try to "restore" I pressed VOL + and - and power and appeared to restore options, but does not even work.
    It all happened when I tried to update the rom, then tried to restart and poof never gave anything.
    Any solution?? The phone is a Motorola xt532, but may give clues as to others, because the procedure should be similar
    sorry my english
    I can onlythrough a combinationof keysto entermode:
    MBMflash mode
    Domino+W+G
    Version: 1.09
    BootloaderUSBinitenablesecureboot
    Butwhat I do now?
    Rescue Squad thunderbolt_nick's Avatar
    @nickburress2k2
    I'm not familiar with the phone, but have you tried factory resetting it and then restoring?
    Sent from the God of phones. Thunder....THUNDER! ... THUNDERBOLT!!
    Jan 2012
    Quote Originally Posted by thunderbolt_nick View Post
    i try all, but i can't enter in recovery mode
    and battery is empti
    somo solution?
    Super Moderator 252chevyboyz's Avatar
    North Carolina
    13 times
    jfhrtn
    Have u tried plugging it in to both the wall charger and usb cord on the computer to try and charge it? Not too fimiliar with the device but hopefully we can get you back up and running.
    Do you have a backup of the original rom? You can try to flash the original rom back to the device if you can get into the settings
    Sent from my Liberated D2
    Droid 2/Liberty 2.0.1/Oc'ed/1.3ghz
    Visit our sister site Droidforums.net for more info
    Jan 2012
    I haveabackup of the "Titanium Backuproot"stored inSDCARD
    buthow torestoreabackup from thePCbecause the phoneonce connectednothing appears, I can notenterrecoverymode
    Jan 2012
    Olá
    Já a uma semana segui um totorial da net para rotear o telefone, no enatanto deu bronca e tenho de recomeçar o trabalho, o problema é que a bateria acabou e o telefone não está a carregar a bateria, de modo que vou alimenta-lo através de outra bateria da mesma voltagem e amperagem.
    O problema é que a bateria tem 4 pontos de contacto, + - e outros 2 no meio, esses outros 2 para que servem?
    Obrigado
    Somewhere on Kamino
    83 times
    No idea what you typed. English please.
    North Carolina
    13 times
    jfhrtn
    Quote Originally Posted by trivial View Post
    Olá
    Obrigado
    I translated the post...
    Hello
    Already one week followed a totorial the net to route the phone at enatanto gave earful and I have to resume work, the problem is that the battery died and the phone is not charging the battery, so I feed it through another battery of the same voltage and amperage.
    The problem is that the battery has four contact points, + - and other two in the middle, these other two are they for?
    thank you
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site. Hope you resolved this problem.
  1. Turn Any Android Smartphone into a NFC Device
    By cereal killer in forum Android News
    Last Post: 01-11-2012, 10:46 AM
  2. motorola i1. MESSED UP!!!!
    By jdmdeco in forum Rescue Squad Help
    Last Post: 12-26-2011, 01:00 AM
  3. Email messed up
    By Janet1219 in forum Samsung Transform
    Last Post: 08-27-2011, 07:29 AM
  4. I think I messed up something
    By Bridgett30 in forum LG Ally Help
    Last Post: 01-11-2011, 04:58 PM
bootloader usb init secure boot enabled
factory reset xt532
full reset xt532
hard reset motorola xt532
hard reset xt532
mbm flash mode domino plus
motorola mbm flash mode bootloader usb init secure boot enabled
motorola xt532 factory reset
motorola xt532 hard reset
xt532 hard reset
xt532 hardreset
xt532 motorola recovery mode
xt532 recovery
xt532 recovery mode
xt532 root android forum
