problem message box keep appear
This is a discussion on problem message box keep appear within the Introductions & Site Assistance forums, part of the Android Discussions category; Hi..my name is maz..i ' m really new w this android...i already downloaded w a lots of programs... Now i have prob that msg always ...
Thread: problem message box keep appear
    Android Lurker maznifah's Avatar
    Jan 2012
    Unhappy problem message box keep appear
    Now i have prob that msg always appears as please chech your internet
    Connection java.lang.NullPointerException..can anybody helps me...
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    Hi maz, maybe you've downloaded a bad program? Try uninstalling some of them and see if that fixes your issue. If not, a factory reset might be needed.
    Super Moderator 252chevyboyz's Avatar
    North Carolina
    13 times
    jfhrtn
    Welcome to the community and sorry you are having problems. It does sound like you might have installed a bad program and a factory reset would probably benefit the situation. As wicked said you could always try to uninstall a few of the programs first before the factory reset. hope you can get this resolved. Dive on in and enjoy the community
    Sent from my Liberated D2
    Droid 2/Liberty 2.0.1/Oc'ed/1.3ghz
    Visit our sister site Droidforums.net for more info
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site.
  1. problem recieving picture message
    By chevell27 in forum HTC EVO 4G Tech Support
    Last Post: 01-19-2012, 08:52 PM
  2. First Message
    By victormumo in forum Introductions & Site Assistance
    Last Post: 08-18-2011, 07:22 AM
  3. Replies: 1
    Last Post: 07-09-2011, 06:56 PM
  4. text message problem
    By scrnmachron in forum LG Ally
    Last Post: 09-07-2010, 02:04 PM
  5. Text message problem
    By GCwaverider21 in forum LG Ally Help
    Last Post: 09-03-2010, 11:31 PM
chech your internet connection
check internet connection java.lang.nullpointerexception on kindle
how do you check your internet connection java.lang.nullpointerexception
kindle fire internet connection java.lang nullpointerexception
kindle fire please check your internet connection java lang error message
on kindle fire hd error message please check your internet connection java.lang nullpointerexception?
please chech internet connection java.lang.nullpointerexception
please chech your internet connection java.lang.nullpointerexception
please chech your internet. connection java.lang.nullpointerexception
please check internet connection java lang error
please check your internet connection java lang nullpointerexception
please check your internet connection java lang nullpointerexception android
please check your internet connection java.lang.nullpointerexception
please check your internet connection java.lang.nullpointerexception android
