Problem logging into forum
This is a discussion on Problem logging into forum within the Introductions & Site Assistance forums, part of the Android Discussions category; I've got two workstations at home that are running Ubuntu. I'm not able to log into the forum from either one of them. I get ...
Results 1 to 8 of 8
Thread: Problem logging into forum
    Junior Member ewhinger's Avatar
    Question Problem logging into forum
    I've got two workstations at home that are running Ubuntu. I'm not able to log into the forum from either one of them. I get a message saying that my password is invalid. I use a Windows workstation and am able to log in without any issues. :confused:
    Senior Member Lendal's Avatar
    That doesn't seem possible, does it... Check your Caps Lock, just in case. Can you log in with your phone?
    Checked the caps lock several times, haven't try the phone yet. Will give it a try this evening.
    Member jdsatyr's Avatar
    the site would not recognize my password last night either ended up having to have it send me a new one and rest it am using win7
    Senior Member AirborneDude's Avatar
    Southern California
    I have several Linux boxes and haven't had problems. Did have problems with XP and Vista, but I think it was because I used my 5 logins up and didn't wait the 15 minutes...
    Senior Member jmgib's Avatar
    Kentucky
    I had a problem yesterday I believe where it wouldn't allow me to log in from a WinXP machine on IE7. Later on it did let me in. Not sure what was up.
    Member Spooky Electric's Avatar
    I was having this problem on my machine at work. I just downloaded chrome, and it wouldn't let me sign in. I had it saved to remember me in Mozilla and it would open up just fine. When I signed out though it wouldn't let me sign back in. I sent a message to one of the admins and they sent a reply about a bad / corrupted cookie. I deleted all my cookies, and temp internet files, then rebooted my computer and it finally worked.
    Problem solved
    I deleted the cookies and was able to log in without any problems. Thanks for all the suggestions.
  1. Powerful converter tools for JVC,Panasonic,Canon,Sony,Flip Camcorder
    Last Post: 09-08-2011, 04:10 AM
  2. Welcome to the HTC Aria Forum on Android.net
    By danDroid in forum HTC Aria
    Last Post: 02-10-2011, 03:52 AM
  3. Replies: 0
    Last Post: 01-03-2011, 04:53 PM
  4. De-T-Mobile-ify your G2?
    Last Post: 12-05-2010, 10:13 PM
