ringtones and notification problems. I need help
This is a discussion on ringtones and notification problems. I need help within the Introductions & Site Assistance forums, part of the Android Discussions category; So I just got this phone and love a lot about it. But I'm having some problems figuring out a few things. 1.) How do ...
Thread: ringtones and notification problems. I need help
    Junior Member sheenaphoto's Avatar
    1.) How do you adjust the ringtone volume to be different from the notificatication volume?
    .......I have looked through every setting in the settings menu and cannot find the box you uncheck to. make the two different.
    2.) How do you turn email and text messages off or to vibrate during a call?
    3.) What does force stop mean in the manage applications menu?
    I appreciate any and all the help I can get!!!!!! Thanks!
    I personally use applications that will give you a better customization of your profiles. There are many that you can find and download in the market.
    I aslo downloaded a widget for my homescreen that will turn your ringer to silent or vibrate or tone.
    You use force stop when you want to stop an application from running. You will also see force close errors as well while using some applications.
    deleted by author
  1. Randomly clears out ALL txt messages!
    Last Post: 01-12-2011, 11:33 PM
  2. Force Landscape Mode
    Last Post: 11-18-2010, 09:19 PM
  3. Galaxy s power pack...
    Last Post: 10-28-2010, 12:08 PM
  4. Adjust unlock time
    Last Post: 10-24-2010, 01:05 AM
  5. Samsung Epic 4G Case Reviews
    Last Post: 09-18-2010, 03:10 PM
android incredible notification ring problem
how do i unsync the ringtone volume and the notification volume on my galaxy s3
problems with droid dna notification ringtones
separate ringtone and notification volume
