IMO - Bad Battery Charger
This is a discussion on IMO - Bad Battery Charger within the LG Ally Accessories forums, part of the LG Ally category; While it does work, quite well, as an emergency charger, it killed 2 batteries on my Dare - after an emergency fill the batteries would ...
Thread: IMO - Bad Battery Charger
    Android Jr Member 671's Avatar
    While it does work, quite well, as an emergency charger, it killed 2 batteries on my Dare - after an emergency fill the batteries would not hold a charge. It holds a AA battery inside and a plug in mini usb cord.
    This was my experience with this charger. FYI
    Thanks for the tip 671.
imo batteries
imo battery
imo battery charger
imo charger
imo in baterry
what is battery imo
what is imo batteries
what is imo battery charging
