Register
Air vent mount
This is a discussion on Air vent mount within the LG Ally Accessories forums, part of the LG Ally category; I have looked through other threads and don't find this mentioned so thought I would ask folks about it. I would rather have the cell ...
+ Reply to Thread
Thread: Air vent mount
    Super Moderator sherongb's Avatar
    2 times
    I have looked through other threads and don't find this mentioned so thought I would ask folks about it. I would rather have the cell phone mounted on the air vents. Saw this one and would like to find out what folks think about it: Harriet Carter GPS holder
    Thanks for any feedback you can give.
    I bought an Arkon from Amazon for 5 bucks. I had to file the side down a little to allow the USB cable to plug in but it works fine.
    http://www.amazon.com/exec/obidos/AS...tpfastfunec-20
Sponsor
lg ally vent mount
