Register
Finally a working LED flashlight!
This is a discussion on Finally a working LED flashlight! within the LG Ally Apps forums, part of the LG Ally category; Hope it works on mine....
+ Reply to Thread
Results 11 to 13 of 13
    Android Lurker processed in everything's Avatar
    Jun 2011
    If you're seeking something brighter and quieter, I actually use my screen but in the form of an app called Color Flashlight - it uses your screen or your camera flashlight - your choice - and you can make the screen any color you wish - I have the app in my most used main window and simply tap it and voila! I have it set to the brightest white for the most light. I've often had people with other phones ask me which app it was after we used it to find something at a party or at night as we approach a dark porch/door cuz they loved how bright it was.
    Super Moderator CR6's Avatar
    9 times
    Thanks, i'll have to give this one a try. I use TeslaLED and it works great. Never realized my led flash was that bright until I downloaded this app!
    tap'n
Sponsor
ally flashlight app
com.lge.hiddenmenu
com.lge.lghiddenmenu
flashlight app for lg ally
lg ally app hidden menu?
lg ally flashlight
lg ally flashlight app
lg ally hidden menu
lg ally secret menu
lg hidden menu ally
lge.hiddenmenu
lge.lghiddenmenu
lghiddenmenu
what is com.lge.hiddenmenu
what is com.lge.lghiddenmenu
