Need help with Error: Device Offline
This is a discussion on Need help with Error: Device Offline within the LG Ally Hacking / Development forums, part of the LG Ally category; I am currently trying to root my LG Ally. All drivers installed. Folders set up correctly. The phone is recognized when i put this into ...
Thread: Need help with Error: Device Offline
    Android Lurker ivorykeys87's Avatar
    I am currently trying to root my LG Ally. All drivers installed. Folders set up correctly. The phone is recognized when i put this into the command prompt ( adb push c:\android\sdk\tools\su\asroot2 /data/local/ ) however it claims my phone is offline. I don't understand, debugging is enabled, the phone is on and plugged in...I don't know what else to do. Please help. Feel free to email me or call 772-579-1757 ivorykeys87@aol.com
    Personally, I would just use the Universal Androot app to root your phone. It's a one-click root option that does everything for you. And it's just as easy to unroot the phone if need be. That's how I rooted mine and it worked great.
    Quote Originally Posted by Joe View Post
    And where exactly do i find this app? Not on the android market i assume?
    I got it from the market way back when, but I don't know if it's still there. Worth searching for. If you do a Google search for it, you should come across some webpage that has it for download.
adb command error device offline
adb device offline error
adb error device offline
adb galaxy s4 offline
adb push error device offline
adb push error: device offline
android error device offline
android sdk device offline
error: device offline adb
error:device offline
galaxy nexus adb device offline
how to clean android sdk from offline devices
sdk error device offline
