Help with the SD card
This is a discussion on Help with the SD card within the LG Ally Help forums, part of the LG Ally category; Title basically says it all, but how do you view/manage files on the sd card?...
Results 11 to 20 of 39
Thread: Help with the SD card
    Android Lurker mule65's Avatar
    Either through your PC or an app like Astro file manager.
    Quote Originally Posted by MasterObiwan View Post
    Thanks for the suggestion, worked like a charm!
    yay!
    Quote Originally Posted by Joe View Post
    follow this thread - should help
    http://www.lgallyforums.com/topic/72-sd-card/
    Do I need to tell the Ally where to save pictures and downloads or does it already know to save things on the SD card?
    I believe apps go to your phone's memory and d/l stuff goes to your SD - the next Android update allows for apps to be saved to sd cards. We are all hoping the Ally can do that - but I am not sure the cpu will be able to handle some of the update's features.
    Quote Originally Posted by janeant View Post
    I just got my Ally and I love it so far. My only problem is I took out the pre-installed sd card and replaced it with the one from my blackberry because i have a bazillion pictures on the sd card that i didn't want to lose or figure out how to transfer over. How do I set the settings so that the pictures are saved on sd card and not on the internal memory?
    Janean
    you need to xfer the pics to a computer and then manually to an sd card - the next Android Update will allow saving pics to sd - I may be wrong about pics tho and have them confused with apps. What I see so far is pics I receive in gmail or txt get saved to sd card - all else (d/ls and pics taken w cam) are on internal phone memory
    Android Jr Member bksxxx's Avatar
    I took out the 4 gig card and have been using an old 1 gig just because all my pics and music were already on it...Is there anyway to save that stuff on the phone so I can put the 4 gig card back and transfer to it or How else could I transfer evrything to the bigger card??? Any Ideas...
    I'm not sure there's a way to transfer things from the card to the phone like what used to be possible on older phones. Probably not since these phones are meant to handle pictures, video, and music, and that would be too much for internal storage to handle.
    What you can do, though, is purchase a little MicroSD USB Reader. You put the SD card in there, plug it into your PC, and then you can transfer everything to your computer. Remove it, switch to the bigger card that you want to use, plug it back in, and transfer everything from your PC to the new card. Old SD card to computer. Computer to new SD card.
    Here is how you transfer images from the 1 GB card to the 4 GB card.
    1. Plug the phone into the computer.
    2. Pull down the notification bar.
    3. Touch the USB Connection notification.
    4. Touch Mount.
    5. Open Windows Explorer on your PC.
    6. Navigate to the SD Card.
    7. Transer your images from your 1 GB card to the computer.
    8. Pull down the notification bar.
    9. Touch the USB Connection notification.
    10. Touch Turn Off.
    11. Change to the 4 GB card.
    12. Remount the USB Connection.
    13. Transfer the images from the computer to the 4 GB card.
    Thanx...Figured it out. saved everything onto my old phone and then put it on the 4gig card
how do i move my music paradise songs from my lg motion internal memory to the memory card
how import photos from sd card to lg volt
how to move picture files to sd card on lg vista
how to move pictures to sd cards on g vista phones
how to send photos to memory card on lg vista
internal memory upgrade for lg escape
lg android phone vs450pp sd card
lg escape how to save photos to sd card
lg escape move pictures to sd card
lg escape save pictures
lg g vista transferring pictures to micro sd card
lg ms500 downloading music to 16gb sd card
lg ms500 picture to sd card
sd storage on lg motion
transfer pictures to sd card on lg escape
