Battery Help
This is a discussion on Battery Help within the LG Ally Help forums, part of the LG Ally category; Oh, I also had another question for you. Is there away to rename pictures that I have in my gallery, while on my phone. I ...
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: Battery Help
  1. #51
    Oh, I also had another question for you. Is there away to rename pictures that I have in my gallery, while on my phone. I looked but did not see a way to do it.
  2. #52
    Quote Originally Posted by nicolett80 View Post
    You can use ThinkFree Office. Navigate to where the photos are stored, if they where taken with the camera they should be in the DCIM/Camera folder. Just long touch the photo and then touch rename.
  3. #53
    I knew You would know, that's why I asked. LOL. But, I learned the hard way that renaming the pics makes it so your not able to view the pic anymore. I thought it would work like like it does when you rename a pic on the PC. I was also able to do it on my Env3.
  4. #54
    You should still be able to see a renamed image in your gallery as long as you didn't remove the file extension (IE: .jpg) from the file name when you renamed it.
  5. #55
    OK, don't know what I did wrong the first time cause I thought i didn't remove the file name, but got it now. Thanks!
  6. #56
    Android Lurker bramsaur's Avatar
    help, someone please help me determine what the battery is for a lg ally and is there a stand alone charger for it. who carries them ? I am having a dickens of a time trying to match up the code on the battery at web sites. Thanks, I appreciate it
  7. #57
    Android Lurker phillybizzle's Avatar
    Does anybody elses phone take a really really REALLY long time to charge back up?! I keep noticing services that are running in the background that I know I didn't enable doesn't make any sense, and I know it's a cause of my shi**y battery life and my phone is only 3 days old
  8. #58
    Hi philly, go back to the first page of this topic and it tells you how to improve your shi**y battery life. http://www.lgallyforums.com/topic/113-battery-help/
    All kinds of things are goin on even when the phone is just sitting there. Remember, it's a miniature computer that you can make phone calls with. It has to keep on top of things, check for updates, new data, get the weather forecast, monitor your alarm and calendar settings,..check for text and email....etc.
    You just have a little to learn, like me. Lucky for you, we have this site. .
  9. #59
    Just remembered,.........read this also.... http://www.lgallyfor...tery-to-charge/
    The topic is "How long does it take your battery to charge".
  10. #60
    Android Lurker barrynew1's Avatar
    I am new to this forum. I have had my LG Ally for about 2 months and love it . . . except that the battery drains quickly during the day with very low use. I followed the instructions on the thread and identified that the Maps application is eating 97% of my battery useage. Can anyone tell me how can I turn it off?
  1. Fs: Mint droid bionic with extra battery and battery charger
    By livspop in forum Android Hardware for Sale
    Last Post: 01-20-2012, 05:50 PM
  2. Replies: 1
    Last Post: 08-09-2011, 01:33 PM
  3. Replies: 3
  4. Battery
    Last Post: 02-04-2011, 03:17 AM
android settings for 3200 mah li-ion battery
battery for lgl75c cell phone
battery help/lgl75c
battery used by cell radio
battery used by mobile radio
how to reduce battery used by cell radio
how to root lgl75c
lg lgl75c battery
lg lgl75c extended battery
lgl75c battery
lgl75c battery life
lgl75c extended life battery
lgl75c phone battery
lgl75c root
lgl75c specs
