Originally Posted by
John23ally
RBW, you're undervaluing your input. Excellent response.
My own experience with my Ally: I've had it almost a month now, and the first two weeks were rough. In the first two weeks, I downloaded a lot of apps, made a lot of changes, and generally "pimped out" my phone. ;-) During that two-week period, my phone probably restarted on its own six-10 times, and frankly, I didn't know what to make of it. Nor did I make a big deal of it, because the phone did, at least, restart. It wasn't like it froze and I had to pop out the batter or anything like that. It was annoying.
I was more concerned with battery life and onboard memory usage. As a result, i started paring down apps and I noticed that, beginning in the third week, my phone started running much more smoothly. As has been noted in other threads on this forum, I found my phone to run even more smoothly when I started using the LG home theme. In the last 10 days, I believe my phone has crashed and restarted only one time, and that was when I was in Google Navigation. In the first two weeks, Google Nav tended to be especially flakey, so one restart in roughly the last two weeks -- and that while using GN -- feels like significant progress to me.
In the last couple of days, I've started to add back some apps, but slowly. Thus far, the results include: increased battery life; better OS stability; smoother operation overall.
Here's my 2 cents' worth: I think much of the problems I encountered in the first two weeks were caused by operator error. I now don't think you can load a bunch of apps on a phone at the same time and expect stability -- it only makes sense that not only will third-party apps conflict with pre-loaded apps, but they'll conflict with each other. I have also learned to deal with the phone's lag time. Even using the LG theme, it still pays to give the phone a second when switching between apps, between home screens, when waking up the phone, etc. Indeed, the best way I've found to make my phone restart is to try to force it to follow several different commands when it is lagging behind. More operator error.
As a result of all the above, my Ally is now a relatively smooth-functioning machine. Overall, I'd give it 6 of 10 stars. When I factor in the price, however, I give it 9 of 10 stars. This is not a top-of-the-line Android-based device. It is the cheapest Android-based device in the Verizon arsenal, at least as of this writing, and that makes it entry-level by definition. If blazing speed and zero appreciable lag time had been that important to me, I would have ponied up the extra 0 and gotten either the HTC Incredible or the Droid 2.
Also, because it is entry-level, the Ally is a first foray into the world of smartphones for myself and many others on this site, and as such, it is going to have to bear the brunt of criticism that it probably doesn't deserve.
With respect to Brent, I don't feel like the Ally is a POS; it simply is what it is. However, if for some reason Google/Android and LG don't see fit to release FroYo for the Ally, then I will have to agree with you, albeit, with regret. Even as I write this last sentence, I'm biting my own tongue: I still have confidence that FroYo will be made available for the Ally.
