Frequently Called
This is a discussion on Frequently Called within the LG Ally Help forums, part of the LG Ally category; How can I delete the frequently called contacts under the favorites menu?...
Results 1 to 8 of 8
Thread: Frequently Called
    Android Lurker Flipper's Avatar
    Quote Originally Posted by Flipper View Post
    You can't.
    Thanks Ally Android.
    At least I can stop wasting my time trying.
    If you download the app History Eraser from the market, you can get rid of them.
    Thanks nicolett
    Quote Originally Posted by nicolett80 View Post
    When I used History Eraser, it did not have an option to erase frequently called numbers. I just reinstalled it and tried again. It did erase the numbers that were there but now there are two numbers in the list for people from Facebook who I have never called and don't even have their phone numbers.
    It may work good enough for what the OP is wanting.
    Android Lurker ahines2002's Avatar
    Download 'HistoryEraser' by DUMAPIC from the Android Market. Select 'Contacts'. When you see 'Select target-All frequently called (in Favorites tab), hit 'Ok'. App will also erase the call log, standard browser, google apps (beta) and miscellaneous. So far, I've only erased my favorites. That was great!
    Android Lurker JavaSnob's Avatar
    Quote Originally Posted by ahines2002 View Post
    Thank you! I had the exact same question and your answer was just what I was looking for. Yay!
android clearing frequently called
erasing frequently called numbers
frequent favorites android how it works
history eraser app did not clear my frequently called list .. what will? help
how do i clear my frequently called list from my samsung galaxy centura phone
how do i delete frequently called droid
how dose the most frequently contacted tab on samsung avant work
how to delete frequently called from droid
how to delete frequently called list android
how to delete frequently called numbers on galaxy s3
how to delete frequently called on android
how to delete frequently called on galaxa centura
how to delete my frequent contacts on a droid dna
how to erase frequent
i can not erase frequently called numbers on my android help
