Phone belongs to
This is a discussion on Phone belongs to within the LG Ally Help forums, part of the LG Ally category; When I turn my phone on it says this phone belongs to. How do I put my name there?...
Thread: Phone belongs to
    Android Lurker wandak's Avatar
    I am not familiar with any settings for this. When I turn my phone on, I get the Verizon splash screen and then the Android splash screen. Next comes the Locked screen where it shows the time, date, and charge status. I have never seen it say anything else.
    I've never seen that either.
    That probably got installed by an app you installed, perhaps a free antivirus app? if thats the case my advice would be to just uninstall that app. its not necessary and takes what little space we have on the Ally. Virus's aren't really an issue on Linux and even if you did get one, just do a factory reset.
    Android Lurker ThePooper's Avatar
    Cleveland, OH USA
    This IS from the antivirus program. To set the text, or disable the message completely, follow these steps:
    Open the antivirus app
    Press the menu button (to the right of the home button)
    Settings
    Remote Management
    Enable lost message (checked enables the message, unchecked disables it)
    Lost message (you can configure the text here)
android forum
android lg phone how to put phone belongs to
android this phone belongs to
find where this phone # belongs too
lg phone belongs to
nexus 5 this phone belongs to
nexus this phone belongs to
