Bluetooth A2DP Connection
This is a discussion on Bluetooth A2DP Connection within the LG Ally Help forums, part of the LG Ally category; Hi. I'm new here, and I just have one question. I have an LG Ally(obviously), and the problem I have is with connecting to a ...
Thread: Bluetooth A2DP Connection
    Android Lurker socobandit's Avatar
    Hi. I'm new here, and I just have one question. I have an LG Ally(obviously), and the problem I have is with connecting to a Pioneer cd-btb200. I can pair and connect no problem to the phone part, but to use the bt audio, I have to disconnect and reconnect. I have tried both using the phone to find the pioneer, and vice-versa with the same results. Both ways, when I start the car, it will automatically connect to the phone, just not the bt audio. The only workaround I have found is to put a bluetooth settings shortcut on the home screen, then manually disconnect and reconnect. I'd really prefer to fix it then work around it. I'm wondering if maybe the sdp profile in the phone isn't doing it's thing. The bt audio section in the radio does not have a manual or auto setting, just the phone section does, and I have registered the phone to the unit for auto connect. Anybody have any ideas? Thanks!
    Rick
    bump...somebody's got to have an idea
    Sorry socobandit, troubleshooting bluetooth devices is not an easy thing to do. In most cases, only someone who has the same bluetooth device as you can offer assistance. I would suggest contacting the manufacturer of the device to see if they have any tips.
    Thanks...Ill try calling them and see what they say.
  1. Bluetooth connection problem
    By crableg in forum Sony Xperia X8
    Last Post: 01-10-2012, 04:22 AM
  2. Android A2DP connection through program
    By chinnadurai.d in forum Android Forum
    Last Post: 06-16-2011, 08:39 AM
  3. Bluetooth Connection; How To !
    By Jelina in forum LG Ally Help
    Last Post: 03-01-2011, 08:01 PM
  4. Bluetooth Headsets with A2DP
    By TechN9ne1730 in forum Motorola Backflip Accessories
    Last Post: 06-23-2010, 06:44 AM
  5. Bluetooth A2DP
    By elitegunslinger in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 03-11-2010, 08:27 PM
a2dp connection
a2dp lg ally
android a2dp connect
android bluetooth a2dp auto connect
android bluetooth a2dp connect
android bluetootha2dp
android bluetooth????a2dp
android bluez a2dp
connecting droid 3 a2dp
lg ally a2dp
lg ally bluetooth connection on and off
lg android a2dp
pioneer bluetooth auto connect lg
use bluetooth lg ally
will droid 3 work with a2dp bluetooth
