Task Killer
This is a discussion on Task Killer within the LG Ally Help forums, part of the LG Ally category; Ok, so I downloaded task killer because my phone was having really bad lag for the last few days and I thought maybe that was ...
Thread: Task Killer
    Android Lurker Smshly616's Avatar
    Ok, so I downloaded task killer because my phone was having really bad lag for the last few days and I thought maybe that was the issue. Now I have read some stuff about it and want to delete it, but when I go to my manage apps area there is no task killer in the list. I got a notification in the white bar area that said it had been downloaded....but now I can find it to delete it....I really appreciate the help.
    Thanks!
    Go to the Market and hit Menu. Touch Downloads. It should be listed with Open or Uninstall as options when you touch it.
    You can also download an Uninstaller App.
app killer for lg ally
my lg ally is lagging really bad
what is a task killer for ally?
