Zoom
This is a discussion on Zoom within the LG Ally Help forums, part of the LG Ally category; Hey all, Searched all over and couldn't find an answer. Is there a app/hack instead of pushing the settings button in the camera to access ...
Thread: Zoom
    Android Lurker phillybizzle's Avatar
    Hey all,
    Searched all over and couldn't find an answer. Is there a app/hack instead of pushing the settings button in the camera to access the zoom, is there a way to have a set slider bar on the main camera screen? it would be soooo much easier!!
    Hey philly, I moved your question over here because you'll get an answer quicker. Like you said pushing the setting button works, but wait til AA gets here. He's the camera expert,...hell, he's the Ally expert! Some of the other members might know of a way also.
    If you use the camera much, take a minute and check out his camera topic, really helpful,.... http://www.lgallyforums.com/topic/331-camera-settings/
    With the default camera app, there is no way to do it. I don't root or use hacks so I don't know if it is possilbe to do it that way or not. A search of the market brings up dozens of camera apps but none of them look like they will do what you want either. In most cases, settings are never placed on the main camera screen.
ally how to zoom with camera
android ally camera zoom
android slider zoom
does the ally camera zoom
how to use zoom on lg ally camera
lg ally camera zoom
lg ally how to magnify searches
lg ally zoom the camera
where is the camera zoom on ally phone
will the camera on lg android zoom
zoom with lg ally camera
