Verizon backup
This is a discussion on Verizon backup within the LG Ally Help forums, part of the LG Ally category; I deleted backup assistant from my phone because it was allway's taking up memory and battery,I did this yesterday and now all my contacts are ...
Thread: Verizon backup
    Android Lurker summithut3's Avatar
    I deleted backup assistant from my phone because it was allway's taking up memory and battery,I did this yesterday and now all my contacts are gone!
    Android Jr Member angelfire123's Avatar
    did you check your google account? im quite alarmed if verizons backup assistance is capable of wiping contacts from google
    I removed the Backup Assistant too but I had made sure to put all my contacts into Google first. I had no malfunctions aside from learning the hard way like you the first time.
    Android Lurker HockeyMom's Avatar
    Franklin, WI
    How did you delete Backup Assistant? It doesn't appear in my Manage Applications list.
    I rooted my Ally using Universal Androot.
backup assistant verizon lg ally
backup contacts from my lg ally phone
bakup 21/8/2010
delete backup assistant verizon
how to back up contacts on lg ally to verizon
how to back up lg ally
how to backup lg ally
how to delete backup assistant
how to delete backup assistant from android
how to delete backup assistant from verizon phone
how to delete backup assistant through my verizon
how to remove backup assisant from lg ally
how to work backup assistant on lg ally
lg ally 2.2.1 model back up assistant
verizon bakup assistance
