Help - Default Calender
This is a discussion on Help - Default Calender within the LG Ally Help forums, part of the LG Ally category; I messed up a little bit today ... I uninstalled the default calender, corporate calender and corporate email .. and probably some other important things. ...
Thread: Help - Default Calender
    Android Lurker Lafter's Avatar
    Now I cant get my gmail calender to sync with jorte.
    I also cant seem to download apps from the market now.
    And im getting a bunch of force closes.
    Does anyone have some advice for an idiot ?
    Hi Lafter,... so ya just deleted 'em, huh? And now you have restarting problems. Well that's too bad,...you ruined it. But lucky for you, you're a member of this site, and we just might be able to save it.
    First step,...you're not an idiot. You're among Ally friends here. But beware, we do have 1 cranky member.
    Second step,...realize I started this posting teasing you!
    Third, and hopefully the last step, depending on the particulars, you might try a reset explained very thoroughy here,... http://www.lgallyforums.com/topic/250-reset-how-to/
