Screen Orientation on the Ally
This is a discussion on Screen Orientation on the Ally within the LG Ally Help forums, part of the LG Ally category; Hello all, I just wanted to run something by the members. Does your screen auto rotate when the keyboard is closed? I have it checked ...
Thread: Screen Orientation on the Ally
    Android Jr Member Darkhorse153's Avatar
    Does your screen auto rotate when the keyboard is closed? I have it checked in settings but the only time it rotates is when I slide open the the keyboard.
    I have tested it out with and with out the check box in settings to and it seems to behave exactly the same way.
    Anyone else able to confirm this as a bug?
    Android Lurker HockeyMom's Avatar
    Franklin, WI
    Mine would auto-rotate even with the screen closed for the first few days I had the phone. Then it quit doing it. I started using LauncherPro and it is now rotating again even with the keyboard closed.
    Hi Darkhorse, H M. Here's a little more on this,... http://www.lgallyforums.com/topic/749-rotating-screen/
    Thanks for the thread link...
    Just to confirm and elaborate a bit though from reading the other thread it sounds like the default home on this phone is not supposed to auto rotate.
    All of my apps behave exactly like they should when rotation occurs. Seems like LG put some hooks in the UI that link the slide out and ignore the accelerometer when at the home screen.
    Android Jr Member Kevin_lgally's Avatar
    Mine used to rotate without the keyboard open, then it just stopped. That's why I searched out this thread. I tried toggling the settings "orientation" on and off a few times, but no luck. Weird.
    Android Lurker akara's Avatar
    Quote Originally Posted by Kevin View Post
    Yeah same here first 4-5days it would rotate but now it doesn't...
    and that thread you linked too seems to be gone.
    I will try launcher pro if its free.
    **EDIT**
    Downloaded launcher pro and it has 7 screens you just have to change it in settings. Awesome.
android auto-rotate screen closed
android rotate screen programally
lg ally auto rotate option
lg ally home screen rotate
lg ally no rotation
lg ally screen rotation
lg ally screen wont rotate
lg ally wont auto rotate
lg ally wont rotate
lg slider display doesnt rotate
lg vs740 screen do not auto rotate
lgally screen doesnt rotate
my screen wont auto rotate on my lg ally
rotat screen orientation lg ally
