Missing Home Wifi
This is a discussion on Missing Home Wifi within the LG Ally Help forums, part of the LG Ally category; The first week I had my Ally, it saw my home wi-fi no problem. After that - nothing. It can see it - it just ...
Thread: Missing Home Wifi
    Android Lurker sciwitch's Avatar
    The first week I had my Ally, it saw my home wi-fi no problem. After that - nothing. It can see it - it just can't connect - its gets hung up on "obtaining IP address...".
    Suggestions?
    Reboot your wireless router then try again to connect.
    Nope, that didn't work. Any other suggestions?
    Quote Originally Posted by marioval View Post
    Have you turned off and restarted the phone? I found this helped my WiFi connection after messing with the settings.
    If not, have you cycled your connection? Basically it is like when you connected the router the first time. Unplug the devices. When you reconnect let each establish a connection before connecting the next device.
    BTW, even when I have no WiFi notification on the top of the phone I know I am connected because some things that claim to work on WiFi only still work. Also, the phone defaults to 3G over WiFi according to the manual.
    Nope... tried that too. The Ally seems to be able to find every wi--fi spot in the state, except for the one sitting in the middle of my house. Actually - it can see it, and "remembers" it (back when it used to work) - it just gives up after trying to obtain an IP address.
    Sigh.
cannot connect lg ally to wifi
cant connect my lg ally to home wifi
lg ally can't connect to wifi
lg ally cannot find wifi
lg ally cant connect to wifi
lg ally ip address
lg ally obtaining ip address
lg ally wifi cannot connect
lg ally wifi problems
lg ally will not connect to my wireless
no wifi on lg ally
obtain ip address lg ally
verizon ally cannot connect to wifi
why can't my verizon lg ally connect to wifi?
why wont my lg ally cornect to my wifi
