Voicemail
This is a discussion on Voicemail within the LG Ally Help forums, part of the LG Ally category; How do you set up your voicemail? I don't want to use visual voicemail...just the regular one....
Thread: Voicemail
    Android Lurker lacarroll2's Avatar
    If you're using Verizon to handle voicemail you don't have to do anything. Go into Settings > Call Settings and make sure Voicemail Service is set to "My Carrier". It should be there by default anyway. If you want to use Google Voice for your voicemail, just sign up for an account on your PC and it will walk you through the process of setting up the phone and dialing the test number.
    ok thank you! i have one more question...where do i go to set my voicemail password?
android set up voicemail
android set up voicemail password on phone
how do i set up voicemail on android
how do u set up a voicemail on a lg android
how to reset up voicemail on amazon fire
how to set up voice mail password on android
how to set up voicemail android
how to set up voicemail in lg l33l android 5.0
how to set up voicemail on a android phone
how to set up voicemail on android phone
how to set up voicemail on fire phone
howtosetupvisualvoicemailonfire
i don't want to use visual voicemail
setting up voice mail on lg android
