alt + z for vibrate mode isn't working
This is a discussion on alt + z for vibrate mode isn't working within the LG Ally Help forums, part of the LG Ally category; Hi, So I've had my LG Ally for about a month now, and I just learned that the shortcut for vibrate mode is alt + ...
Thread: alt + z for vibrate mode isn't working
    Android Lurker kthurrell's Avatar
    Hi,
    So I've had my LG Ally for about a month now, and I just learned that the shortcut for vibrate mode is alt + z, but when I do this nothing happens. There's no indication (such as a symbol in the notification bar) that the command has registered and notifications continue to come through with audible alerts. I'm a teacher and in a few weeks I'll need to have my phone in my classroom with me, and the last thing I want is for it to be going off with every email. If anyone knows anything about getting the shortcut to work, I'd love to hear it!
    Thanks!
    I just tried it and pressing alt then the z key worked for me. It turned the phone to Vibrate mode. I think you need to be on the Home screen in order for this to work.
    Yup, I was on the home screen. Nothing happening...
    pmd
    pmd is offline
    Android Jr Member pmd's Avatar
    I am having the same problem
droid vibrate isnt working
lg shortcut to vibrate
vibrate isnt working droid
