Calendar view
This is a discussion on Calendar view within the LG Ally Help forums, part of the LG Ally category; I've determined that my most useful calendar view is the 1 day view. However, when I exit the calendar and come back later, it has ...
Thread: Calendar view
    Android Lurker ghpup's Avatar
    I've determined that my most useful calendar view is the 1 day view. However, when I exit the calendar and come back later, it has often reset- sometimes to the week view, sometimes to the month view. Is there a way to make sure it always opens in the day view, or short of that, to make sure it opens in the last view I was using?
    Thanks again- you guys always have an answer.
    Hi pup, I don't use the calendar much but I thought it would open again displaying the same view. Hmm.. the answer temporarily eludes me.
    Anyway, wait til one of the big boys get here because you're right. We always have the Ally answer.
    Opps, this one got missed somehow.
    The answer would be "You cannot change the default view for the calendar app that comes with Android."
    If you open the calendar app and change the view to day view, the next time you reopen the app it should still be on the same view you last had. But this would only work until you rebooted or the app was killed by Android or an ATK. It would then default back to the Month view.
    Ahhh- Then I'll quit trying to make that happen. Thanks for the reply. I just posted another calendar question - maybe you can help with that as well.
    Thanks again
    ghpup
android calendar day view
android calendar view
android calendarview
android calendarview mark day
android razr cannot change calendar view
calendar day view android
calendar resets to week view in android
calendar view lg ally
change to calendar view on lg ally
how to change calendar view on lg ally
lg ally calendar app
lg ally calendar month view
lg ally calendar view
