How to take out the battery
This is a discussion on How to take out the battery within the LG Ally Help forums, part of the LG Ally category; I just got the LG Ally, and i cant figure out how to take out the battery...is there a special way or something?...
Results 1 to 9 of 9
Thread: How to take out the battery
    Android Lurker pkcbms101's Avatar
    Quote Originally Posted by peyton View Post
    Yeah, it's called a crowbar. Seriously, both myself and my Verizon rep tried for fifteen minutes to get mine out. We never succeeded.
    I read somewhere, likely on these boards, to try the corner of a credit card. It worked like a charm.
    (Sorry for no credit to whomever wrote it. IDR where it was.)
    I use my finger.
    Android Lurker HockeyMom's Avatar
    Franklin, WI
    Wow, the credit card works great! And I was also able to use the credit card to easily remove the case on my phone so I could get at the battery. Thanks for passing along this tip!
    Also, if you have a stick of dynamite handy......
    Yeah credit card works the best. There is a notch at the top of the battery, this is where you should slide the card in. The credit card plastic is soft enough that it won't gouge anything else.
    Android Jr Member dll932's Avatar
    OK, fine...how do you take off the COVER? Nothing in the book that comes with the phone!
    Quote Originally Posted by dll932 View Post
    Just push it up toward the camera. It should slide right off.
android cant figure out my new battery
android cant figure out my new battery limits
can i take the batterh out of a motorola android phone
droid how to take battery out
droid mini battery removal
googlevideoshowtotakebattoutoftab
how do i get the battery out of my motorola tablet
how do i get to the battery on my droid mini
how do you take a battery oout of a android proscan tablet
how do you take out baytery in android lgg6 phone?
how to take battery out of android phone
how to take battery out of android tablet
how to take out battery of redmi 2 phone
how to take out battery on droid
take out android phone battery
