PDF Help
This is a discussion on PDF Help within the LG Ally Help forums, part of the LG Ally category; Originally Posted by x9911 it does have the open button in the email, when i touch it it says fetching attachment, then says cannot play ...
Results 11 to 15 of 15
Thread: PDF Help
    Quote Originally Posted by x9911 View Post
    it does have the open button in the email, when i touch it it says fetching attachment, then says cannot play video
    If that is the case, then you have a program that has been set as a default to open PDF files. The only way to clear it is to find the program in applications and touch the Clear Defaults button.
    IE: If I had set the default for PDF files for Adobe and I wanted to clear it, I would:
    1. Push the menu button. (From the home screen.)
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Find Adobe.
    6. Touch Adobe.
    7. Touch Clear Defaults.
    The biggest problem you will have is in finding which app has been set as the default.
    Also, only downloaded apps show in Manage Applications by default. You may have to change it to View All in order to check the apps that came with the phone.
    1. Push the menu button. (In Manage Applications)
    2. Touch Filter.
    3. Touch All.
    Android Lurker cfipps's Avatar
    I am having the same problem myself, and this information did not help me any.
    Sorry cfipps, when you find the answer, please share it with us.
    Android Lurker x9911's Avatar
    finally got this resolved. called verizon tech support (very helpful!), and the lady had me log into my hotmail via the browser and not through the app. and whatta ya know, worked like a charm!
    thanks to everyone that offered help on this matter. hope this helps others with this issue
    Android Lurker jsmola's Avatar
    I tried the directions above and never found Adobe to clear. Now I cannot install it either. Useless without pdf access!
android, how do i download an email attached pdf
delete pdf downloads lg ally
delete pdf files ally lg
delete pdf files lg ally
delete pdf from lg ally
help opening pdf file on ally phone
ho to access downloaded file on lg ally
how to delete downloaded pdf files on lg ally
how to delete downloaded pdf on lg ally
how to delete pdf files on lg ally
how to open pdf file on lg verizon ph
im trying to view a pdf document from verizon's website on my lg ally
lg ally access pdf files
lg ally adobe reader delete files
lg ally how to remove pdf files
