PDF Help
This is a discussion on PDF Help within the LG Ally Help forums, part of the LG Ally category; When i try to open pdfs attached in emails, it tries to fetch and then says unable to play video. any help on how to ...
Results 1 to 10 of 15
Thread: PDF Help
    Android Lurker x9911's Avatar
    any help on how to open and view pdf email attachments?
    thanks
    I described the process in Your Last Post about the PDF Viewer App.
    Are you sure the file is a PDF? You should see the file type as the last three letters of the attachment. Options for attachments within the E-mail include Download and Preview. Is this true for you?
    Preview does not always work. In that instance I Download, and when it is done it asks with which program I would like to view the attachment. For PDF use ThinkFree Office, for JPG use Gallery, for MP4 use YouTube or Browser.
    If this is not the case, please describe your process and I will try to help.
    its definately a .pdf file. dont see any options ( download or preview). i hit the open button, it says fetching attachment, then says cannot play video. what am i doing wrong? thanks
    Are you using Gmail or another e-mail app? I tested opening a PDF from Gmail and using the Yahoo mail app and both worked successfully. I haven't tried the default mail app that came with the phone because I don't have an account linked to it. Maybe someone else can test that.
    Also, have you tried opening the PDF on a computer? Maybe the file is corrupt...not sure.
    opens fine on pc. im using default email linked to msn/hotmail.
    Not sure I can help on that since I don't use the default e-mail app. Can you open PDFs outside the e-mail app? Try navigating to this link and see.
    http://www.google.com/url?sa=t&sourc...efYVYB29MqEQzQ
    I just emailed myself a pdf and was able to open it it in the default email app without any issues. I was able to use both Think Free and Adobe to open it.
    how do i open the pdf in another app while in email?
    It should just have an open button in the email. You touch the open buttona and if you have more than one app that opens the type of file, it will ask you which app you want to use.
    it does have the open button in the email, when i touch it it says fetching attachment, then says cannot play video
android, how do i download an email attached pdf
delete pdf downloads lg ally
delete pdf files ally lg
delete pdf files lg ally
delete pdf from lg ally
help opening pdf file on ally phone
ho to access downloaded file on lg ally
how to delete downloaded pdf files on lg ally
how to delete downloaded pdf on lg ally
how to delete pdf files on lg ally
how to open pdf file on lg verizon ph
im trying to view a pdf document from verizon's website on my lg ally
lg ally access pdf files
lg ally adobe reader delete files
lg ally how to remove pdf files
