Charging Port
This is a discussion on Charging Port within the LG Ally Help forums, part of the LG Ally category; Ok I used to plug the charger into my phone and it would b good it charged fine... now... I don't kno what happened but ...
Thread: Charging Port
    Android Lurker tink087's Avatar
    Ok I used to plug the charger into my phone and it would b good it charged fine... now... I don't kno what happened but when I plug it in sometimes the red charging light doesn't go on and it doesn't charge I have to move it around then it will go on... anyone kno what 2 do?
    Hi tink, whether you have to move the USB end, or the AC end one of them is not making good contact. If the USB end doesn't fit right, something happened to the phone or the USB terminal end of the cord. If it's the AC end, try plugging it into a different outlet. I'm assuming you're using the OEM charger, if not, who knows.
android charging port
are%20all%20lg%20ally%20charger%20ports%20the%20same%3f
broken charger port ally andro
broken charger port on lg ally
charging port for android lg phone
charging port on android not working
charging port on lg
charging port on lg ally
lg ally charger port
lg ally charging jack
lg ally charging port not working
lg android charger port broken
lg charging port not working
what type of charger connection on lg ally
