Battery Status Over Voltage
This is a discussion on Battery Status Over Voltage within the LG Ally Help forums, part of the LG Ally category; So I noticed today my battery stayed at 100% for several hours which didn't seem right. I have the VizBattery widget and checked the battery ...
Thread: Battery Status Over Voltage
    So I noticed today my battery stayed at 100% for several hours which didn't seem right. I have the VizBattery widget and checked the battery status and it says "over voltage". I rebooted the phone and that seemed to take care of it as the battery went right to 99% after a few minutes or playing around as it should. The phone was not hot and I was using the charger that came with the phone. Any thoughts?
    Hi mari, interesting. I was going to say if the phone had been on the charger the whole time, it may have begun to warm-up, triggering the over voltage reading.
    But since you said it wasn't hot, ...and you were using the Ally charger,...I don't know.
    If you have the time mari, plug it in again, and see if it happens a second time.
android battery over voltage
android overvoltage
battery health over voltage
battery overvoltage
battery status over voltage
over voltage battery android
over voltage battery health
overvoltage android
overvoltage phone
overvoltage phone battery
phone battery over voltage
phone battery overvoltage
phone over voltage
phone overvoltage
