Contacts...
This is a discussion on Contacts... within the LG Ally Help forums, part of the LG Ally category; All my contacts are backed up in backup assistant but none are listed in my gmail account...Is there anyway to get the two to sync ...
Thread: Contacts...
    Android Jr Member bksxxx's Avatar
    All my contacts are backed up in backup assistant but none are listed in my gmail account...Is there anyway to get the two to sync or do I have to add them all manually? I would rather have them in gmail since BA has already lost all my contacts once and I dont wanna let it happen again.
    Greenville SC
    I'm not sure if this will solve your problem or not, but it's worth a shot. When I activated my Ally, I downloaded my contacts from Backup Assistant, and synched the phone to Facebook. When I did that, many of my friends wound up having double contact info -- the Facebook entry and the BA entry -- because the two entries didn't agree perfectly. When I tried to edit the FB contact entry, it told me I couldn't edit it. However, if you hit the hard menu button at this point, it will give you the option to "join" contacts, so I went through and joined all the pairs of duplicated accounts. It was a pain to have to do each pair manually, but once done, it was pretty slick.
    Hope that helps.
bksxxx
