Constant Reboot! HELP!!
This is a discussion on Constant Reboot! HELP!! within the LG Ally Help forums, part of the LG Ally category; I got an LG ALLY last week and it would reboot every 10 minutes. There was no way to shut it off. It would even ...
Thread: Constant Reboot! HELP!!
    Android Lurker angel_lgally's Avatar
    I got an LG ALLY last week and it would reboot every 10 minutes. There was no way to shut it off. It would even turn on when I shut it off with the Verizon chime. So...I asked for a new one. It is doing the same thing. I like the phone except for this problem. Is anyone else dealing with this problem?!
    Your not the only one. Here is another thread about the same issue: Constant Freeze Rebbot
    However, I don't think the issue was ever solved.
    If the new one is doing the same thing (rebooting frequently) take it back again and ask them to figure it out, or replace it again. This is not normal.
    Do you mean the phone reboots itself while just sitting there, or when you turn it off, it turns itself back on.
    pmd
    pmd is offline
    Android Jr Member pmd's Avatar
    Mine does that. It freezes for like 3 mins and then turns black and says android for like a minuite. I am assuming that your problems are because of over heating. But I don't know for sure. I think you should do what My friend Minty told you to do. Bring it back as for a new one.
android nexus rebooting with droid red constant rebooting
droid 4 constant restart
lg alley automatically resets
lg ally reboot
lg ally rebooting
lg ally shuts off
lg ally vs740 constent reboot
lg lucid constant restart problem
lg nexus 4 rebooting constantly
lg vn251 keeps resetting
lg vn251 restarting randomly
lg vn251cuting on and off continuously
lg-vn251 constantly reboots
lg-vn251 keeps rebooting
lg-vn251 reboots continuously
