Power Control Widget
This is a discussion on Power Control Widget within the LG Ally Help forums, part of the LG Ally category; I am a new owner of an LG Ally and was reading through the manual. In the Tips section on pg 34 it tells you ...
Thread: Power Control Widget
    Android Lurker tarakcmo's Avatar
    I am a new owner of an LG Ally and was reading through the manual. In the Tips section on pg 34 it tells you you can optimize battery life with a Power Control Widget. When I go to the Home Screen Menu my "Add" key is disabled. My husband has the same phone and he can add this. Any suggestions?
    Thanks!
    Tara
    Greenville SC
    Hi Tara,
    Your phone should have come with the PC widget pre-loaded on one of the home pages (I forget which one). If it's not loaded on a page, just go to a home page with adequate space and long-touch the screen (in an empty area) to call up an on-screen "Add to Home screen" menu. The second item down is widgets. hit that, scroll down to the Power Controller, and touch it and it will load on your selected home screen.
    I hope you enjoy your new Ally!
android forum
android power control support
android power control widget faq
android power control widget help
android power control widget source code
faceniff
help with power control widget android
lg ally power control widget
lg ally toolbar power control widget
lg power widget
power control widget key
power widget settings in lg
