Silent calls & audible notifications
This is a discussion on Silent calls & audible notifications within the LG Ally Help forums, part of the LG Ally category; Hello just got the Ally last week when my 5 year old Envy went AWOL. So far. So good. I would like to have the ...
Thread: Silent calls & audible notifications
    Android Lurker chris48178's Avatar
    I would like to have the phone on silent (vibrate), but my text msgs on an audilble alert. Anyone have any advice?
    -Chris
    Sure thing! Press the menu button and go to Settings. Then select Sound & display and then Ringer volume. Uncheck the box that says Use incoming call volume for notifications and then you can set the volume for each individually!
    Thanks so much. Exactly what I was looking for.
