Relaunch?
This is a discussion on Relaunch? within the LG Ally Help forums, part of the LG Ally category; im sure its a stupid question, but when i turn my phone on, one of my widgets says "relaunch me". what does this mean and ...
Thread: Relaunch?
    Android Lurker x9911's Avatar
    what does this mean and how do i relaunch?
    btw, its a clock widget and it does show up normal after a minute or so, but im just curious
    Sounds like a badly designed widget. if there is nothing special about it then just find another widget. I personally use "fancy Widget". its a great clock/weather widget and its free.
    Just open the App Drawer and hit the Digital Clock app (/Widget). This will restart the widget after re-booting the phone. However, as you stated, if you wait it usually starts by itself.
    This happens to all my Widgets on re-boot. Some just re-start faster than others.
android phone relaunch me
android relaunch me
android relaunch me message
digital clock widget relaunch me
how do i relaunch widgets
how do you relaunch a widget
how do you relaunch widgets
how to relaunch a widget
how to relaunch digital clock widget
how to relaunch widget
phone says relaunch me
relaunch a widget
relaunch me
relaunch me android
relaunch widget how?
