Headphone Jack No Longer Working
This is a discussion on Headphone Jack No Longer Working within the LG Ally Help forums, part of the LG Ally category; So I have only used the headphone once and it worked great. Today when I went to use it, it now no longer works. What ...
Thread: Headphone Jack No Longer Working
    Android Lurker jscottyh's Avatar
    So I have only used the headphone once and it worked great. Today when I went to use it, it now no longer works. What happened? Any suggestions on how to fix it?
    Quote Originally Posted by jscottyh View Post
    Does it not direct the Audio to the Headset? Or are you not hearing anything from either the Speaker or the Headphones? The first thing I would try is to Pull the battery and leave it out for a minute or so, that will do a soft reset on the phone (No Data is lost) ... Don't have it plugged into the Charger when you do this or it will defeat what we are trying to do. Put the battery back in and power up. Try the Headset again. If it still doesn't work check the volume again (I know that sounds silly) Unplug and re-plug the Headset again. Also is your Memory low? Do you have and other sound utilities running?
    If this all fails, then I would say you have a bad Ally and I would contact Verizon support for assistance to see if they can replace the phone.
    Quote Originally Posted by LG_Pro View Post
    Just to clarify for the OP, the volume for media is not the same as the volume for the phone. I would try to play something without the headphones to make sure that my volume was ok then plug in the headphones. If not, try a different set of headphones.
    Greenville SC
    I wouldn't be so quick to blame the Ally -- if all sounds are working normally, but the headphones aren't working with the phone, it might be a bad set of headphones. I'd try different headphones before I'd go pulling the battery (which is kind of a pain) or changing settings. Just a thought...
    Haha its not a bad pair of headphones, its speakers as well. And I have tried both. The speaker on the phone works but it does cut out the sound on the phone when I plug speakers or headphones. Just no sound out the speakers or headphones. Pulling the battery is such a pain since I have one of those holster/cover for my phone but it worked once. haha so I ran advanced task killer to kill all the programs running after powering off my phone and powering back on. Then I opened the music player, success! Ran advanced task killer again, opened up the gallery, played my movie and it worked. Also with doing the task killer there are no audio apps running at that time. So with this being my work around, is there something software/driver wise screwing up the phone? In laptops it has Jack Sense written in the drivers to change the output from the laptop speakers to the headphones when you plug in headphones. If you remove the Jack Sense part of the driver, it will play through the speakers and the headphones. If the driver has a bad line to return audio to default you get no sound out of that output again.
    Android Lurker Headphone Jack Problem's Avatar
    But even if that doesn't fail, wouldn't you say s/he has a bad Ally? How often would a person have to do this battery-removal routine before it would be considered that their phone is a lemon and they need one that actually works? That really sounds to me like a messed up phone even if your advice works and fixes the problem temporarily.
    Android Lurker kephreal's Avatar
    Jun 2015
    Just blow!
    Treat the phone jack like an old video game cartridge. Just blow really hard into it. Also put a little hot breath on the headphone adapter piece as well. Should work like brand new.
  1. Headphone Jack - Jacked Up...
    By jjwalker2 in forum HTC EVO 4G Tech Support
    Last Post: 02-07-2014, 12:31 PM
  2. aux cable tip broke off in headphone jack!!
    By Zach in forum Nexus One
    Last Post: 01-28-2011, 10:13 PM
  3. 3.5mm headphone jack causes media player to skip songs
    By Supraz01 in forum Nexus One Tech Issues / Bug Reports
    Last Post: 08-30-2010, 04:13 PM
  4. Nexus one 4 pole headphone jack
    By crazyrockets in forum Nexus One
    Last Post: 08-27-2010, 10:52 AM
  5. Headphone Jack
    By mimaketi in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 03-19-2010, 04:14 AM
headphone not working lg
headphones aren't working on android
htc 510 headphones not working
htc desire 510 earphones not working
htc desire 510 headphone jack
htc desire 510 headphone jack not working
htc desire 510 wont recognise headphone
htc desire headphone not
lg g3 headphone jack not working
lg phone headphone jack not working
lg power audio plug not working
lg stylo 2 headphone jack not working
lg stylo headphone port not working
sound wont work on lg volt
when your headset is not responding with htc desire
