Android Lurker
Messages Saved as Drafts
Some of my messages save as drafts. When I checked the user guide it said if you delete something using that arrow key with the x in it, the message will save as a draft. But today even when I didn't delete or back-up it was still saved as a draft. It took one message 6 tries of reopening it, typing a little more, then resending it until it finally went out. Is this a bug? Am I doing something wrong? It is very frustrating, any advice or comments would be welcomed.
09-07-2010 06:17 PM
# ADS
Android Junkie
The only way I know to save a message as a draft is to back out of the message before sending it.
Super Moderator
What about the "Save As Draft" button? The bottom of the message I am composing offers Send, Save As Draft and Discard.
The arrow key with the X? I think you mean Backspace. Instead use the "U-turn Arrow" key in the left-hand corner (the Back button), which will back you out of the message you are typing and save as draft. Or, am I totally missing what you are asking?
Android Junkie
Originally Posted by
Qasar
I don't see this in the default messaging app. I get Add Subject, Attach, Send, Insert Smiley, Insert Quick Text, and More. More only gives me Discard, All Threads.
Android Lurker
Qasar
I don't see a "save as draft" button. To the right of my composing box is a send button. In the user guide I read that using the backspace button would result in the message saving as a draft, but mine are even when I don't use the backspace. A couple of times when I've opened the message again and added a few words it has "sent" but it's getting worse. Last night I added to the message 7 times and it still was saved as a draft.
Super Moderator
LOL I read the post as E-mail messages. I was in the middle of a few I was writing, so those messages were on my mind.
This commercial interruption was brought to you from poor sleep.
We now return you to your regular scheduled broadcasting.
Android Lurker
I was replying to an email and I saved as draft. Where did it go? How do I go back to it? Where do the sent emails go? When I click on the icon for my email, all it offers me by sight is my inbox messages.
Thanks!!
Super Moderator
Look under labels. That will show you your sent folders, draft, trash etc.
tap'n
