SD Card / Computer Connection Issues
This is a discussion on SD Card / Computer Connection Issues within the LG Ally Help forums, part of the LG Ally category; I am having trouble getting the SD card in my Ally recognized by my computer when connected by USB cord. I am ultimately trying to ...
Thread: SD Card / Computer Connection Issues
    Android Lurker Mariellen's Avatar
    I am having trouble getting the SD card in my Ally recognized by my computer when connected by USB cord. I am ultimately trying to load some music from my SD card to my computer. It wont even show any files when I connect the phone and go to My Computer. I am running Windows 7 and upon connection the notification says LG phone connected not a USB Mass Storage like other computer and phone connections I have made before. I feel like its something real easy and its driving me crazy! Any and all help is much appreciated!!! Thanks in advance.
    I use Windows XP, I dont if its different on Windows 7 but..... After you connect the phone, on the phone, slide down the notification panel and click on the USB Connection message, then click on mount. Your PC should now load the phone as a USB drive. Make sure when you are done you go back to that notification on the phone and click unmount before you unplug the USB cable.
    I will give it a shot! Thanks so much for the help, truly appreciated.
connect usb lg phone to computer sd card?
connecting lg ally pc
how do you connect sd card to computer
how to connect lg ally to computer
how to connect sd card to computer
howtoloadmusiconmyally
lg ally conect sd card to computer
lg ally sd card computer
lg ally shows connected to usb cable
lg ally unmount sd card
lg connect sd card issues
lg connect sd card problems
lg connect to computer without sd card
usb connected unmounts lg ally sd card
usb mass storage not showing on lg ally
